I have a Enduro Pro FSR 2002 with stock crankset and was wondering if this would fit and if it would be a good deal/upgrade. Its $60, probably could get it for $50 from the guy. Thanks for the help guys!
Shimano XT Octalink crankset 175mm, with Shimano Octalink 73mm sealed bottom bracket. 9 speed, 22/32/44 tooth chainrings, self-extracting crankarms. Picture is just a stock photo of XT Octalink cranks, don't have an actual photo of my cranks. The outer & middle rings are worn but still usable, inner ring is like new. Right crankarm has wear marks from my shoe. Splines on crank and bb, and pedal threads are perfect.
specs:
One Key Release: Crankset can be easily removed from bottom bracket with an 10mm hex wrench
Hollowtech Crank Arm: Yes
Splined OctaLink Mount: Yes
One-key Release Crank Bolts: Yes
4-arm Chainring: Yes
Chain Compatibility: Super Narrow HG
Number of Teeth: 44-32-22T
Bolt Circle Diameter: 104/64mm
Crank Arms: forged aluminum/hollow type
Weight: 617g (175mm)
specs:
