I am going to install a new bottom bracket cartridge and crankset in my '02 Specialized
Hardrock. The bottom bracket is worn and the chain rings 22/32/42 are quite worn and
appear to be riveted on the original equipment Specialized 175mm forged cranks.
Would Shimano Alivio FC-M410 Compact Crank Set work correctly ?
I would use the same square taper and a new bottom bracket cartridge with the same
size as the original (68 x 110). although subsequent years of hardrock went to 68 x 113.
I assume staying with the 68 x 110 would be most sensible.
The two issues are:
1) if the chain line is going to be correct with the Shimano Alivio FC-M410
Compact Crank Set ,
2) if this 9 speed crankset will work properly with an 8 speed rear derailleur / cassette
on the bike.
Or is there a more suitable crankset in this price range. Not really wanting to change
the whole setup to 9 speed but if this seems the proper thing than the appropriate
advice is welcome.
The two issues are:
Compact Crank Set ,
on the bike.
advice is welcome.
