I will be upgrading out of ISIS and into outboard bearing in a few days. I have Truvative Stylo team cranks (ISIS) in black that are a year old and will let them go on the cheap. They are a great crank. PM me if you are interested.TXrider said:I need some suggestions for a crankset for my Schwinn Homegrown that will soon be my singlespeed. They will need to work with an American Classic ISIS bottom bracket. Any help would be greatly appreciated.
Pricepoint has the FSA V-Drive Extreme cranks arms for $35 right now. Not the prettiest, but hell for stout. Get that, a Blackspire SS ring for $25, some chainring bolts and your in business with a great crankset for about half of what most "SS" cranksets cost. If you really want to give it that special touch, get the RaceFace bashguard for $27. These are bulletproof and most importantly, really look cool. You will not get a better ISIS crankset no matter how much more you spend.TXrider said:I need some suggestions for a crankset for my Schwinn Homegrown that will soon be my singlespeed. They will need to work with an American Classic ISIS bottom bracket. Any help would be greatly appreciated.
I can recomend these also. We trials riders use them and they last a long time.BrianU said:Pricepoint has the FSA V-Drive Extreme cranks arms for $35 right now. Not the prettiest, but hell for stout. Get that, a Blackspire SS ring for $25, some chainring bolts and your in business with a great crankset for about half of what most "SS" cranksets cost. If you really want to give it that special touch, get the RaceFace bashguard for $27. These are bulletproof and most importantly, really look cool. You will not get a better ISIS crankset no matter how much more you spend.
Brian
To find the best gear ratio to fit your chain, just Google "chain length calculator" or something similar. There are a bunch of different calculators out there.and all you need to know is your chain stay length (bottom bracket to rear axle c-c measurement). Some calculators will even give you ratios depending on whether you want to use a half link or not. I used one to find that a 34 x 20 fits my 19 inch Homegrown just fine.Homer Simpson said:I'm running a 32x16 on my homegrown, but that's not a magic ratio. I'd like to know what the magic ratio is for a homegrown. But until then, the tensioner stays on the bike. I think there is a formula to calc the magic ratio, but I don't know it. But somebody out there does.
Bensbike on eBay has or at least had "New" 2000 Homegrown Pro frames for $199.I don't see any listed on his site but I'm thinking if you call they can hook you up. You will need an ICBM headset which they also carry as a OEM item. I've purchased several for my son as he grows. His first one, a 12" Homegrown was built up with XT / X-9 components and with AC wheels it came in around 18lbs. I'm just about finished with his new rig which is a 15" Homegrown decked out with SRAM XO and should come in about the same. Excellent frame but comes with 20mm disc mount. I run the Avid Ultimates V's on his which works great since he weighs about a buck.Homer Simpson said:Hmmmm, someone else with a Homegrown SS. They make nice SS bikes, light, stiff and responsive. I wish Schwinn still made these bikes.
You can get a Truvativ fairly cheaply. I've got the bontrager/truvativ crank on my 29er SS, works well. More importantly, pick a good chainring.
