1 - 20 of 22 Posts
So their website would suggest the weight is 65 grams for the cobalt SLdirectset. Well, like a happy weight weenies I purchased it thinking that's what I'd be getting....instead 85.6 grams (w/o starnut) is what I received. Apparently in the description it also states preload is 25 gms. Not even sure what the hell that is (my fault obviously), however when the weights on the website states 65 gms that should be the total weight. Disappointed I was in thinking I was getting a headset that would be lighter than my extralite headset for 1/2 the price. No pics to prove since my cardreader is kaput.
http://crankbrothers.com/directsets_cobaltsl.php
Get your freak on!
The headset is 65grams, this is the same way Chris King and others weigh their headsets . 'Preload' refers to the top cap, starnut and bolt.
i personally think they are a great weight considering they also come with 5 year warranty.
Discussion Starter · #3 ·
I didn't realize that. They are even at 85 grams total, much lighter than the kings at 115 ish grams. Looks like I"ll be using some lightweight topcaps and ti bolts to bring it down a bit now.
dmcgoy said:
How is spending ~$90 to save ~30 grams a great deal? When I needed a new headset, I just bought a cheap FSA Orbit headset which weighed about 120 grams. It was $22.
1.i get less than wholesale on most bikes/parts.
2. i wouldnt do this to everybike i own(about 10-11), but one or two light/race bikes its worth it.
Discussion Starter · #8 ·
Yeah, that orbit weighs ~same as a king. Thinking of saving 1/8 lb by going with crank seemed reasonable...after all this is the weenie section. Intending to only save 30gms, the purchase would not have occurred.
A Real Winner.
I have a Crank Bros. Cobalt C and an Opium C. They both weigh 69 grams. Just an FYI, headset weights are generally the headset cups, bearings, crown race, that ring thing that goes around the fork on the top, and the top bearing cover. Headset weights do NOT include starnuts, topcaps, and starnut bolts as these items are not "headset specific" and lighter parts can be used. For example, the Crank Bros topcap weighs in at 9 grams, but I have some plastic ones that only weigh 3.
The point is the headset weight is just for the headset itself. Here are some other 1 1/8" threadless cup style headset weights as an FYI for comparison:
Crank Bros. Cobalt C-69 grams
Crank Bros Opium C-69 grams
Woodman Axis SL-90 grams
Cane Creek S8-97 grams
King NoThreadset-99 grams
Cane Creek S1-186 grams
All weights do not include the topcap, starnut, or preload bolt. They include everything else that is in the actual headset though. As you can see, the Crank Bros. is clearly the lightweight press in cup style headset right now. This is an easy way to drop an ounce off your bike.
Party!
Discussion Starter · #10 ·
Party!
Looks like I'll be using my extralite top cap and ti bolt to bring down the weight a bit. Now I know about stated weights for headsets. :rockon:
I dig trails!
Thanks, I did not know that either. Funny, other headset makers don't mention that.
That said, I just installed the Opium C (DH) version for my 6" bike, and the weight savings was a good 100+g. :thumbsup:
Note also that the C versions bearings material will be stronger than the Stainless, so if you ride in the dry, save a few additional bucks. see here: http://www.pvdwiki.com/index.php?title=The_BEST_Headset
P
Discussion Starter · #13 ·
Hand/of/Midas said:
technically after your bearings are preloaded and your side bolts are tightend you dont need a topcap. Bmx kids do this alot, but then again those stems weigh 200g, not 100g,and dont have torque specs.
Yeah, I used a schmolke top cap on my extralite setup, however on this one I guess I don't have to either, but I do have the extralite top caps around.
What lighter and cheaper..if that's possible...alternative for top caps. Tune gum gum?
1 - 20 of 22 Posts
