Hmm it is going to depend on a lot of things you have left out:
rings, bb, bash, etc,etc...so it is not really quite so easy to compare apples to apples. Plus you are not even comparing the same length cranks....nor specific to bb width..nor items that are for the same use... nor in the same price range. You might as well add in XTR,, noir, and gravity gaps.....
You best bet for REAL weights for most of this stuff (at least enough to give you a realistic comparison)is sicklines. They have a weight gallery and all parts have to be pictured on a quality digi scale.
The other reality is that 100grams plus or minus will make ZERO difference in any facet of MTB (actually plus or minus a few pounds (other than outter wheel weight) will make no difference at all on a DH bike)....other than forum posting.
You need to decide what your use will be, how much you want to spend, and the differing technology offered. That will lead you to a part that will be the best for your use....not weights.
