Sure, but.... dropping the BB has advantages that are totally worth having a shorter crank for me. Especially since I really don't notice it all that much anyway.
Agreed.
Notice I saiid I USED TO proclaim the benefits of long cranks.
I’ve changed my tune. Not because a longer lever is any less valid than it used to be but rather because I’ve changed the way I ride my bikes, and crank length affects more than power.
FWIW I’m currently riding 175mm cranks even though my inseam is the same length it ever was: 36”.
During the 36 years I’ve ridden mountain bikes, I‘ve employed cranks lengths of 170mm, 175, 185, 190, 195, 202.
I would have tried shorter cranks but my legs are loooooong. No reason for me, personally, to go there.
What’s changed is we’ve got dropper posts now and we ride totally differently. Nobody wants to do high performance riding with their feet as far apart as 200mm-ish cranks will place them. Nor spin circles as large as those long arms make when trying to negotiate techy terrain. Nor hit their pedals on the ground a lot, which today’s frames would force a rider to do if their cranks are any longer than 175mm at the most.
But for pure power, give me long cranks. Remember, this comes from someone with legs long enough to operate them.
After all the personal crank length experiments I’ve performed are said & done, I’ve come to this conclusion:
It doesn’t matter. Well, it does matter but it depends on what your priorities are.
I can climb faster with longer levers (aka cranks) and a higher gear.
I can climb the same terrain with shorter cranks and a lower gear, I just go slower.
So yeah, shorter cranks make plenty of sense. You just won’t go as fast up the hills.
And you’ll enjoy the descents more with shorter cranks because your feet will be closer together.
If your BB is low, you’re kind of forced into the second camp in order to avoid pedal strikes.
Which is too bad if you wanted to make that choice on your own but whatever, the bicycle industry hasn’t been big on offering lots of choices lately, from setting up your own gearing to crank length to much of anything else.
But know this: longer cranks have their advantages and so do shorter cranks.
It’s not like one or the other is best. It depends on priorities as well as leg length.
But people won’t buy this. They’ll insist that one other the other must be best.
So the arguments will continue.
=sParty
