Longer is better for SS. (Starting the crank wars again
I start with the idea that there are two modes of using the cranks on an SS. One is the usual sitting and pedaling on the flats to an interesting destination. The other is standing and applying greater force to the cranks - usually climbing, but maybe just for acceleration.
When standing one applies body weight and more force by pulling the handlebar up. One then tries to apply this maximum force to the "sweet spot" of a nearly level crank. Let's designate the sweet spot by an angle through which the crank moves, the actual angle could be different for each rider but just for argument say it's 45 degrees.
The arc length through which the crank moves increases as the crank length increases. If the rider applies his usual maximum force then the total energy transferred to the bicycle is greater with a longer crank. Energy (Work) = Force * Distance.
This energy has to show up as greater distance climbed per stroke or greater acceleration per stroke. The rest of the pedal stroke is wasted energy, just an effort to return the pedal to a position for another push down. If the rider with shorter cranks increases the RPM to catch up in terms of Energy (Work) transferred then he will have more wasted strokes and therefore be less efficient.
Knee damage is brought up in context of applying force (maximal?) throughout the pedal's travel. I am self-regulating in that respect, I don't try to pull hard.
There is another possibly secondary effect of smaller cranks and higher RPM's. Knee damage occurs when maximal force is applied to an immovable object. A crank at the bottom of the stroke is immovable. With higher RPM's the rider's timing to "left off" the force becomes critical. Equally important is to not apply force too soon at the top, higher RPM's are a problem here too.
What about "spinning out" on the flats? Yes it does occur, yes I can ankle it to make my foot move less than the pedal. But on most slopes I find that a full aerodynamic tuck beats pedaling (especially a spinning SS with shorter cranks) and it takes no energy.
