If you do things right the first time you will avoid the pitfalls that notoriously follows hack jobs
-squeeking, creaking etc etc
truvativs bbs require 30ft lbs of torque per cup(torque is different dependant on the manufacturer) brand new bbs usually have an antisieze applied to the threads in the middle. though I always apply 242 loctite to the threads of metal cups(first 3 threads) this is enough the maintain the bb cups in place to prevent creaking, or loosening off. grease is temporary and only seems to muffle the inevitable.
As per the wize guy who plugged his holes in his bb shell with grease, the hole is meant for condensation collected within the frame to drain out. Not so much a problem for aluminum frames, but the bb on the other hand.
Get a torque wrench, borrow a torque wrench and follow manufaturer installation(some fat guy didnt just type them out for you to throw them away)
