1 - 5 of 5 Posts
I've mounted a XTR M952 crankset onto a '06
Santa Cruz Blur LT with a XTR M952 BB (112.5mm). I
think the spacers on each side of the BB are 1.5mm? My question
is, can I add more spacers to the driveside so the crankarm doesn't hit
the chainstay? The crankarm hits when a put force on the cranks (which is
pretty much always).
Do It Yourself
The 112.5 mm XTR bottom bracket with one 2.mm spacer on each side should work on the Blur. I had that same setup on my Superlight. Those would normally be fairly stiff cranks so if you're getting that much flex, I would suspect that the spline interface is wearing out on the cranks arms.
Not sure if this helps any, but here is a quote from the Santa Cruz website.
What size bottom bracket should I use on my Blur LT?
This depends on the specific crank manufacturer.
The Blur uses a 68mm BB shell and - like 95% of the bikes out there - requires a 47.5-50mm chainline*.
(*chainline is the measurement spec from the center of the BB shell to the middle ring)
All of the new external bearing cranksets should work fine - just follow the manufacturers instructions for set-up with a 68mm BB shell.
Most ISIS cranks use a 113mm spindle.
Older XT cranks (2002-2003) use a 113. Some LX cranks from'03 - '04 use a 121mm. Old XTR cranks (before the external bearings) should use a 116mm.
Call your crank manufacturer if you have doubts - just tell them you need a 50mm chainline. ALWAYS buy for a 68mm shell.
Discussion Starter · #5 ·
Fixed it.
Called Santa Cruz, and they confirmed that because I'm
using the older XTR M952 cranks, I need to use the 116mm BB,
and two spacers on the drive side...works perfect.
1 - 5 of 5 Posts
