[SUB][/SUB]
The nipple broke, but the spoke was fine--in fact I reused the spoke when I replaced the nipple.
Three months ago, I built up this rim, my first carbon rim, an Ibis 742, with these 14mm high strength aluminum nipples, and these stainless washers(recommended by Ibis), with DT Swiss Comp spokes (2.0/1.8), and an Onyx rear hub.
I used one layer of Kapton tape, which was in good shape when I removed the tire to fix the spoke, and there was no sealant leaking onto the spokes. This is the second drive side nipple that cracked in the last 3 weeks.
After I built the wheel, I noticed that some of the drive side nipples weren't aligning well with the spoke line, which concerned me. Do I need to use nipples with a more rounded head so that they can align better with the spoke line?
