After one week on my new Orbea Alma M50 carbon hardtail, I noticed a ding/crack in the middle of one of the upper chain stays. I never took a hard crash but I did fall over a couple of times on it so it's almost certainly from that. As such it's not a manufacturing defect per se, although I'd say it's pretty shoddy construction if it can't take a normal fall/knock that didn't hurt me a bit.
I assume the best I can hope for from Orbea is a crash replacement discount, but if these frames are so flimsy/fragile then I don't want another one -- certainly not enough to pay more than $100 for a new frame and I expect that it'll be much more than that even with a crash replacement discount.
I've had it looked at by several shop mechanics, all of whom agreed that it's serious and probably the frame has been significantly compromised. The Orbea dealer I took it to is submitting a claim for a new frame but they told me it's probably not likely since in the end it's my fault for letting a rock touch it ungently.
What should/can I do? I assume it's a hard knock (literally) that I need to grin and bear, and just move on after learning the hard (expensive) way not to mess with Orbea carbon. Or is there any remedy? What's it likely to cost me to have the ding/crack repaired? How/where would I go about that?
Thanks in advance for your comments/suggestions.
