1 - 20 of 48 Posts
I purchased a used Giant NRS Air back in March. Last week I cracked the top tube near the seat tube. See picture. I'll assume used purchase, ebay > leads to zero warranty!!!
What are your opinions about tempoary welding job while I find a replacement?
Just another FOC'er
From what I've heard I won't be very strong without going through a full frame heat treatment. That's a pretty complex operation, and nothing I'd consider doing.
FWIW, I've had friends try to fix cracks in aluminum frames with welds, but as expected they never hold very long.
Personally, I'd talk to Giant to see if they'll give you any type of deal.
Anything Rough and Rocky
Whoa! A nasty crack, what happened anyway? Just curious.:D
Well, if you insist on having it rewelded, its pretty good enough for riding again ... but with "lower level" of riding until you find a good replacement for it. Good luck there.:)
Doesntplaywellwithmorons!
Alas giant uses 6xxx aluminiums which require both heat treating and artificial aging after being welded to have sufficient strength for usage, which requires a rather specialized oven to accomplish.
Takw/agranofsalt
Not to mention stripping and repainting. Time for the trash bin, get another frame.
Glad to Be Alive
Jerk_Chicken said:
Talk to Giant, they'll probably give you a crash replacement discount.
just tell them you bought it bran new......
welding the frames weakens the other metal around the weld....then it would have to be heat treated to bring it back up to strength
Banned
this particular frame is not worth the repair. Especially around that zone, especially factoring in the difficulty in finding a place that will honestly heat treat the frame.
1 - 20 of 48 Posts
