Just try again. You can not loosen the bolts too much and you have too loosen them just enough.Mr Pink57 said:
And do not take the 2-3 clicks as absolute. Adjust as needed.
I tend to loosen the bolts. Set the inner pad to ~halfway in the caliper (centering the rotor). Then wiggle the caliper slightly as I pull the brake lever. Lightly hold the caliper with the inner pad flat on the rotor, then then tighten the outer pad. Now tighten the bolts.
Sounds more complicated than it is. I can do it in under a minute.
Also make sure the rotors are true.
