1. Constant clicking/grinding from chain on cassette in every gear after install of new derailleur but doesn't skip or autoshift. Shifting from small to big is good otherwise. Is this a barrel adjustment? (Also installed new chain and cassette.)
2. New Shadow XT doesn't have barrel adjuster at derailleur. Barrel adjuster on shifter is broken. Options?
3. Crank bearings bind/drag when I tighten crank bolt on RF Deus crank. Why?
4. Running two ring set up but can't get the chain to not rub on front derailleur. Either it rubs on the inside of the cage when in the first three cogs when in the middle ring with it adjusted so that the chain is close but not touching the inside of the derailleur cage when in small chain ring/large cog combo....or it rubs on the outside of the cage when in the four smallest cogs. Can't seem to find a cable tension that doesn't rub either place.
I think that's it for now.
Thanks.
Thanks.
