Just wondering what the correct position in which a skewer for your wheel should be closed. Facing upwards, down, sideways? Or does it not matter?
I usually do the front straight up the fork tube and the rear facing backwards in a position where I can get my fingers under it. :thumbsup:ProjectDan35 said:I've been doing the front at about 11 o clock( cant go straight up because of fork), and rear at 10 o clock facing the front of the bike.
Depends on the fork and frame.ProjectDan35 said:Just wondering what the correct position in which a skewer for your wheel should be closed. Facing upwards, down, sideways? Or does it not matter?
Ditto on that. My front skewer is a DT Swiss, ratchet-style and its lever won't clear the bottom of the suspension fork for a 3 O'Clock position so I position it pointing at about 12 O'Clock as close as possible against the front of the fork without actually making contact with it.ProjectDan35 said:I've been doing the front at about 11 o clock( cant go straight up because of fork), and rear at 10 o clock facing the front of the bike.
The reason I asked this is because I put them in a proper position. My LBS always puts them in a position in which they could snag something, or get un-latched. :skep:dexetr30 said:Why does it matter how your skewers are clocked? As long as they aren't in danger of snagging anything on the trail and they are tight enough so as to not allow a wheel to fall off... it doesn't matter.
Send them a link to this thread.ProjectDan35 said:The reason I asked this is because I put them in a proper position. My LBS always puts them in a position in which they could snag something, or get un-latched. :skep:
I should...........floydlippencott said:Send them a link to this thread.![]()
Obviously your view of "proper" is different than theirs.ProjectDan35 said:The reason I asked this is because I put them in a proper position. My LBS always puts them in a position in which they could snag something, or get un-latched. :skep:
I think that this is an appropriate time to respond tha i cannot posible read any of yoru posts because I keep staring at those...I mean....your avitar photo.floydlippencott said:Send them a link to this thread.![]()
