Yup. No conversion needed. 8sp and 9sp cassettes are the same width.dag560 said:Are you able to convert an 8speed rear hub to a 9 speed cassette without changing the hub? Or is the new cassette too large?
Cheers,
Dan
Thanks for the helpFreeRangeChicken said:As TLG said, you should be good with your hub. However, You will have to upgrade you shifter to a 9-speed. Deraileur shoud be okay since the indexing is set by the shifter.
