1 - 3 of 3 Posts
· Registered
I have a SID Race 2007 which has 80 mm travel.
Is it possible to convert it to 100 mm?
I've read that some SIDs can be converted, but I am not sure if mine can.
Here's a picture of the fork.
· Registered
Discussion Starter · #2 ·
I read on the 2007 user manual that this fork can be converted to either 63 mm or 80 mm, but it doesn't appear as 100 mm anywhere.
Is that right? Aren't there 100mm SIDs? (excluding the new 2008/2009 models)
· Registered
Discussion Starter · #3 ·
Admins, you may lock the topic, I found the answer in another forum.
28 mm SIDs can only be either 63 mm (with the spacer) or 80 mm without it.
Only newer 32 mm SIDs can be set up to 100 mm.
1 - 3 of 3 Posts
