1 - 10 of 10 Posts
· Registered
I have the beginnings of a plan to build a new wheel for our TAB shifter and use a 9-speed hub/cassette. I didn't get a chance to look at it last night to see, but is there any issue with mounting a new rd?
Our kids don't shift because the grip shifter is so tight, even with new cable/housing and disassembling/lubing the shifter.
· Registered
Discussion Starter · #3 ·
They're already on 'real bikes' as you put it, but our youngest is 4 and all 3 of them like to ride trails with me.
I figure it's standard 130mm spacing and a 9-speed hub is 135mm but since the frame is steel I can just bend it open and it will fit fine.
I'm also considering an internal gear hub but want to keep total cost down, so who knows.
· Registered
Don't spend that kind of cash. I fixed my son's TAB for less than $5 by getting a cheap indexed thumb shifter.
My solution can be found in these threads.
http://forums.mtbr.com/showthread.php?t=550268
http://forums.mtbr.com/showthread.php?p=6061421#post6061421
· Registered
Well, building up a special wheel will probably work, because you can certainly spread that frame a little, but I don't see how that keeps costs down. It sounds like you're into it, so do something up and show us all what you come out with.
· Registered
Discussion Starter · #6 ·
A new igh would be a few hundred, I can put a new hub/cassette/spokes/rear der. in for probably $100 if I build the wheel myself.
I'm still just toying with the idea and will prob get a trigger shifter first to try as suggested above (and I've thought about, just never acted on).
1 - 10 of 10 Posts
