No, that's not possible.
In metric-layouted shocks the eye-to-eye stays the same within a size bracket and you only change the travel, not the length.
With you 241mm you would need to change the overall length by 11mm and then also limit the travel to 65. So it would require two independent changes. Metric shock standards had been designed to work this way. Imperials are not.
Ride on
Gesendet von meinem Pixel 5 mit Tapatalk
