Not exactly 29er, but here she goes:
A buddy of mine has a steel Mongoose Alta, circa 1993. He found that he can stick a pair of 700c rims on that frame (w/ the original fork) with decent width cross tires.
I think he told me he trouble lining up the brakes for the larger diameter wheel. I know for the front, he can nab a 700c cross fork w/ the canti mounts in the right place, however, the canti mounts for the rear brakes are probably causing a bit more of an issue.
Is there a fix for this? If there is, is it worth it, or should he just scrap the project altogether? He's not hell-bent on doing it, but it would be a neat project.
Thanks in advance.
Thanks in advance.
