Why not get the new Vented helmet mount? It's a pretty cheap accessory and much improved over the older pretty substandard mount.
Where are you connecting the velcro strap? Are you making it fit just like the goggle strap would? Also, how did you get the little clip piece out of the flat surface mount and into the goggle mount? I can't seem to find how I'm supposed to get that rail out...herothedog said:I've just been using the goggle mount and a velcro strap and put it on the right side of my helmet. It is very snug, no issues with it moving around.
http://vimeo.com/herothedog/videos
Insert the camera on the rails in the flat surface mount, hold the camera and lever the clip piece out. Also IMHO forget about the handle bar mount - too much vibration to be useful.locobaylor said:Also, how did you get the little clip piece out of the flat surface mount and into the goggle mount? I can't seem to find how I'm supposed to get that rail out...
do the rails just pry off? should i just try to force it? I don't want to break it and be out of luck until a new mount comes in, but i want the rail section off of the flat-surface adhesive part.ukbloke said:Insert the camera on the rails in the flat surface mount, hold the camera and lever the clip piece out. Also IMHO forget about the handle bar mount - too much vibration to be useful.
Yes. Heavy-duty Velcro is holding the piece with the rails to the piece that has the tape for adhering to a flat surface. Just as ukbloke suggested, if you just slide the camera onto the rails you should be able to pull on the camera to separate the two pieces of the mount.locobaylor said:do the rails just pry off? should i just try to force it? I don't want to break it and be out of luck until a new mount comes in, but i want the rail section off of the flat-surface adhesive part.
Yes, it pries off but in a specific way. Let me try to describe it again. There are 3 pieces - the mount, the camera and then the "insert". The insert clips into the mount, and the camera slides on rails into the insert. The insert has a dial around the outside with a serrated edge that meshes into the mount to allow you to pick an angle of rotation. Look at MarkHL's picture in this thread. There is a tab on the bottom of the mount - nearer the front of the helmet. The other end of the mount has a lip. You need to mount the camera on the insert, and then apply leverage to snap it out of the mount. The side nearer the tab comes out first. You might want to apply opposite pressure to the tab on the mount. There is velcro between the mount and the insert to hold it still. You need to apply enough force to break the force between the velcro and snap it out. It takes a bit more force than you might think is reasonable. It gets easier over time. Frankly I think they should have included two inserts with the camera rather than one. Good luck!locobaylor said:do the rails just pry off? should i just try to force it? I don't want to break it and be out of luck until a new mount comes in, but i want the rail section off of the flat-surface adhesive part.
I never rode with it mounted on top and moved it to the side after viewing the post above me. Yeah, my mount did a separation between the mounting piece and backing tape (opposed to between the velcro as designed) before I even got a chance to use it :-{Pedalphile said:I did the same as MarkHL. It makes an extremely versatile mount - I was able to strap the camera to the side of my Lefty for a nice low angle that shows just a tad of the front tire. I was aslo able to easily strap it to a friends seat tube facing rearward. The possibilities are nearly limitless if you use a long enough piece of Velcro.
I had purchased the vented helmet mount when I bought my camera, and it does serve it's purpose well. Just like herothedog, I mount mine on the side of my helmet - this gets the lens closer to eye level. I've found the camera angle mounted from the top of the helmet is too high and looks unnatural - the side mount is much closer to how your eyes see the action.
You can see these mounts in action here.
-Pete
Flip your monitor!:lol:locobaylor said:i mounted the camera and it was upside down. the video is upside down now. anybody have any tips on how to edit the video to make it right side up? it didn't look like quicktime had a simple button to push to rotate the video...
Windows Live Movie Maker (free) will flip it... http://download.live.com/moviemaker (Vista or Windows 7 required).Pedalphile said:Flip your monitor!:lol:
You just need some editing software that's better than the pos I use (VideoPad - I shouldn't call it names, though, since I'm using the scaled-down free version).
Based on reviews here, I'm leaning towards buying Sony Vegas, although I have no idea if it will flip video or not. I would like this capability as it will allow me to mount the camera upside down as MarkHL suggested.
-Pete
Something's not right. I have the free Quicktime player (v7.6.5), and it plays the .mov files off my ContourHD as smoothly as WMP plays a converted .avi, and they play in QT @30 or 60fps depending on recording mode.MarkHL said:The movie looks like it's strobing in QuickTime (to me). If you look at the Movie Inspector it's only playing about 15 FPS (instead of 30).
thanks for posting this i was wondering how to covert itMarkHL said:Windows Live Movie Maker (free) will flip it... http://download.live.com/moviemaker (Vista or Windows 7 required).
The legacy version of Windows Movie Maker (XP and Vista) will flip it also... Under effects choose "Mirror Vertical".
However first download a free copy of "Any Video Converter" and convert your *.mov file format to an AVI (WMV2 codec) so it can be read by Windows software: http://www.any-video-converter.com/products/for_video_free/ The AVI will play much smoother in Windows Media Player than the *.mov file will play in QuickTime Pro unless you have a very fast computer. The movie looks like it's strobing in QuickTime (to me). If you look at the Movie Inspector it's only playing about 15 FPS (instead of 30).
... should have quoted locobaylor
Refering to my comment QuickTime Pro was only playing my FPS at 1/2 the rate and looked like it was "strobing"Pedalphile said:Something's not right. -Pete
