1 - 8 of 8 Posts
I did my rear tire yesterday, Race King 2,2 SS on ZTR olympic using stans solution. The only hard part was setting the bead, my handpump couldn't cut it, so I had to use the compressor at the local trainstation (3min walk). They were fairly new, and needed a full 60ml squirt of solution because of its huge inner surface, but they sealed pretty quickly.
ivantcs said:
i'm using ZTR olympic rims as well.
will the tires be able to take higher pressure like 40psi?
I took it to 3 bar (~45psi?) to seat the beads, and work the sealant around, but when I'll ride, I'll do so on 1.8 bars max (~25psi?). I weigh around 200lbs
1 - 8 of 8 Posts
