I ran into an issue on #2 that I didn't run into with #1. I'm wondering if you guys may be able to shed some light on it.
I've got a 56% silver brazed 1.25"x0.058 sleeve on my seat tube and I was TIGing the seat stays on and thought I blew a hole in it. I'd gotten about half way around the stay and as I was standing on the pedal (I've gotten away from the pulser and am manually pulsing with the pedal) and just about to back out of it and move on, the puddle basically exploded outward, covering my electrode in molten filler rod and left a crater in the weld. I thought perhaps my gas blew off so I cranked up the gas a bit, hit it good with the steel wire wheel to clean it up, resharpened my tungsten, tried to fill it in and the same thing happened in this one stop. I cleaned it again, moved on and finished the weld out and then came back to that spot and filled it the best I could but it doesn't look great.
I'm thinking what happened is that the puddle got hot enough that the silver mixed with the steel in the ST sleeve and it contaminated the weld. I can't imagine that I burnt through 0.058" and into the silver without burning a hole in the seat stay, but that's all I can think that happened here.
Any ideas?
Any ideas?
