1 - 5 of 5 Posts
tomorrow I will put UST tires on my new stan's olympic wheelset. am I supposed to use the included rim strip with UST tires or only use the tape? the stan's website is not very clear it seems when pertaining to his own wheelsets.
I love Pisgah
Just use the tape and 5gm valves. The rimstrip shouldn't be needed. I'm running Olympic rims so far with non-UST Twister Supersonics, RRalphs, Jimmy Lights..on Olympic rims with sealant, tape, valve.
Whatever
Ditto here. The rim strip doesn't make sense. I got mine last summer before the rim strips were available so I didn't even know about them until now. Is it the same as the ones he sells for other rims?
By the way, I just used strapping tape from a local hardware store, went around the rim 2x, and haven't had a problem in 8 months so far. I'm using non-UST Kenda 2.1's.
Discussion Starter · #4 ·
cool thanks. I wish notubes.com would process my order for tape and stems. taking them forever! guess I will use the rim strips for now. the olympic strip is different, only 38gr compared to 50gr.
the strip...
the lighter rim strip is different from the original one. it is supposed to trap air better than just taping, the downside is a little more weight. with it you can use a bike pump to easily inflate most tires. with tape you might have more problems.
now to those of you running the olympic disk rims. any problems with durability?? i am 190 and ride southern cali trails. i'm usually pretty smooth, but i want a light rim that can handle any mistakes. any feedback would be awesome!!
1 - 5 of 5 Posts
