1 - 11 of 11 Posts
What are the usual size for cone wrenches? I'd like to have a few on hand as I normally end up wrenching on, not only my ride, but friends' rides as well. Normally only MTB but I have the occasional roadie in to adjust as well.
I just bought a complete set. Cone wrenches for some reason are very expensive for what they are. I spent the same on a Park set of every cone wrench that I would have spent on 4 individual sizes
MTBR Member
sasquatch rides a SS said:
Biggest thing that turns me away from double ended is some hubs need both sizes that are on the one wrench, then you're screwed :)
I adjust my cup & cone hubs from one side - only one cone wrench needed. I don't use my cone wrenches on the jam-nut(locknut)....do you?
Even if I did run into the problem you describe, I actually do have a full set(of individual wrenches) in the home shop - the double ended wrenches are for traveling.
Anyways, it sounds like double ended wrenches will suit the OP just fine.
Discussion Starter · #8 ·
Just ordered the Park double ended wrenches about an hour ago. Thanks for the input everyone.
ncfisherman said:
I'll recommend the double ended Park cone wrenches. They have served me well over the last couple years and they are going to be cheaper than a full set with individual sizes.
http://www.parktool.com/category/hub-axles
Hard on the hands but work great for years!
As for the same ones on the same wheel. Min are 14/15 and 16/17 and never ran into an issue yet.
Can Tree Member
You are screwed, but only because you made a purchasing mistake.:eek: I have really old-school Campy cone wrenches, double-ended. 13-14 on one and 15-16 on the other. When you bought them, you were supposed to get two of each/four wrenches in total. I've run into axles where the cone and locknut were both the same size...in that case if you had a single set of single-ended wrenches, you were screwed.
If I ever ran into that issue I would grab a trusty Craftsman wrench. But I did check and none of my hubs have that issue. So I'm good to go.
1 - 11 of 11 Posts
