Hi!
Yesterday I tried to lower the oil level on my MX Comp ETA and I could do it in the air side (no problem there and apparently the oil was way too high - only about 10mm from the top when fully compressed).. that was ok, but on the other side I could get the top cap off, however when I spun the compression nut (in either direction CW and CCW) the whole shaft spun with it, so it didn't loosen) In the end I could not even check the oil level on that side and just reassembled it back.
Does anybody have an idea of how to loosen that nut without grabbing the shaft with pliers or something like that (there are threads on it and it looks easy to mess them up, so I wouldn't try it).
Thanks,
Cris
Thanks,
Cris
