I'm building a new bike as well. If you read all of the posts in the dedicated Nomad C thread, you will come across many opinions on this matter. :thumbsup:DarkDaze said:Someone recently quoted that the DHX5 Air doesn't run as well as the RP23 on a Carbon Nomad.
Anyone else got an comments on this. Building up a new bike.
Seems people are recommending the DHX Coil. Actually more keen on it but feel it would be more prudent to go air for some of the trails around me.Yippee_Ki_YayMF said:I'm building a new bike as well. If you read all of the posts in the dedicated Nomad C thread, you will come across many opinions on this matter. :thumbsup:
In saying that, I have heard that, once set up properly, the DHX works better. Seems to be a few different schools of thought.
I have a Pushed Float R on my MK2 Nomad. So far I just love the thing. It will push the ring off the shaft every ride as well as supple on the small hits. I am still playing around with the SAG setting. I am still getting used to it so I am not sure if its blowing through the travel mid stroke yet or not. I know different bikes and linkage ratios etc. I suppose there's a good deal of difference between a Push tune and factory version? I have very limited experience on my buddy's DHX A. It was very active and he likes to get a lot of pop off the lip at the bike park so he doesn't run much rebound so it felt really bouncy to me. Over all it didn't feel as dampened as the Float R I am running.gticlay said:FloatR pushed with big hit kit - It handled extremely well but I couldn't ever use the last 3/8" of shock travel unless I cased a double or something really harsh. Could feel like I was bottoming out the bike when I wasn't. Push rebound feels like magic and makes the bike pedal even better
I also had a bone stock FloatR with low/low tune. That shock was absolutely the best compromise between the RP23 BV and the DHX-air. I sorta wish I had that particular shock back.
wilsonblur said:I have very limited experience on my buddy's DHX A. It was very active and he likes to get a lot of pop off the lip at the bike park so he doesn't run much rebound so it felt really bouncy to me.Sounds weird to me. I feel like to make a bike have some pop it's gotta be more damped so it doesn't 'squish' off the lips. So it rides more hardtail like, not less. Like I said above - YMMV, JMO, etc.
About 30 seconds easy once you have the shock set up how you like it.DarkDaze said:Some food for thought here. Think I will go with the RP23 and Maybe get the DHX Coil at the same time and swop them over when needed.
How easy is it it to switch them over?
Is there another coil to consider?
gitclay,gticlay said:Sounds weird to me. I feel like to make a bike have some pop it's gotta be more damped so it doesn't 'squish' off the lips. So it rides more hardtail like, not less. Like I said above - YMMV, JMO, etc.
Roco WC Coil. Look for 'em, they're coming in cheaper than the DHX-C, AND can be sent in to Avy to have Craig do some voodoo to it to make it custom. I did it to an old 5th for my MK1 Nomad and it's an amazing transformation to the bike! Just calc your spring weight correctly...the TF Tuned calc is good: http://www.tftunedshox.com/info/spring_calculator.aspxDarkDaze said:Is there another coil to consider?
Sure. Like I said, YMMV. IMO. JMO, I was talking about pop off a jump, not recocheting off successive hitsPau11y said:gitclay,
This isn't a knock on you or your assessment, but it seems you come from a more XC background?
To POP off an air: if you use...say, a 400lbs spring and load it up on the face of the jump, that spring will take your 180lbs, load the energy up in its 400lbs coil (from the g-loading of the in-run) and release that energy at 400lbs like a force multiplier, and spring (pop) you off the lip. Your right tho in that it'll feel bouncy because of the minimal rebound damping. But it's that pogo stick effect ppl associate w/ pop. And if rebound is completely off, the ass-end of that bike will want to come over the top of you when you come off the lip of an air. Air spring or coil spring behaves the same w/ no rebound damping.
What you're talking about w/ a stiff rear shock is not "pop" but more of an uncontrolled ricocheting off of successive hits (too high of compression damping if shock isn't compressing, too slow of a rebound if the shock is packing up). Either case, the rear of the bike will skip around like a rabbit on crack. Remember the days of hardtails on washboard corners... Again, either case, the bike will be in the air more than on the ground. However, in the case of washboard corners w/ very little rebound, the bike will want to POP off of every successive hit and you'll get the same effect of uncontrolled rabbit on crack.
I'm old (remedial) skool...no idea what YMMV meansgticlay said:Sure. Like I said, YMMV. IMO. JMO, I was talking about pop off a jump, not recocheting off successive hits![]()
gticlay said:wilsonblur said:I have very limited experience on my buddy's DHX A. It was very active and he likes to get a lot of pop off the lip at the bike park so he doesn't run much rebound so it felt really bouncy to me.You know how it is when you are using another riders descriptions of things it can lack clarity and detail. I was just quoting my buddy not necessarily evaluating his accuracy. I didn't include that he reduces SAG to about 12mm when he is jumping. I am not sure its so weird. I guess its how you define pop. When shocks are dampened they move slower as you know and with it the PSI jacked up it absorbs and rebounds quickly giving him some sense of "pop" however he's using it. With the way he's running the shock at the bike park its the same cumulative affect as what you are describing a firmer shock loses less energy on the lip. So I am in agreement that his bike rides more like a HT. We are always chiding him for running his shocks so hard on the trail. I just couldn't believe how bouncy it was compared with my Float R or my RP23. Mostly because of how little sag he runs.Sounds weird to me. I feel like to make a bike have some pop it's gotta be more damped so it doesn't 'squish' off the lips. So it rides more hardtail like, not less. Like I said above - YMMV, JMO, etc.
Fixed it for yougticlay said:Your Milage May Vary. You are new skool'd.
It's an easy switch. As for coil options, nothing comes close to an Avalanche coil shock. I have a Woodie on my Jedi (after having tried an Elka, and ROCO) and that thing is amazing. Craig is a genius with suspension.DarkDaze said:Some food for thought here. Think I will go with the RP23 and Maybe get the DHX Coil at the same time and swop them over when needed.
