1 - 20 of 32 Posts
Tires are always making a trade-off somewhere. The Ribmos generally take the "all things in moderation" approach. They're reasonably cheap, but not the cheapest; reasonably light, but not the lightest; reasonably flat resistent, but not the best. Generally they a good tire. I used the 700x28 version for about 2000 miles of commuting and didn't start getting flats until the end of that time (which is typical wear life for me). The 26x1.5 version should be even more flat resistant.
If you're really flat intolerant, the Schwalbe Marathon Plus is the way to go. They also last a really long time, so while the initial cost is comparable to the Ribmo in the long run they're cheaper. The trade-offs with the Marathon Plus are that they're really heavy, have more rolling resistance than a tire like the Ribmo, are fairly hard to mount and don't have the best grip. If you're willing to deal with that, their puncture resistance can't be beaten.
Schwalbe Marathons come in a few flavors as well. Some are more beefed up, others a bit thinner and more flexible. I like the regular HS 420 profile Schwalbe Marathon in 1.5 - 1.75". I haven't had any puncture flats and the tires have roughly 7000 miles on them. The rear is wearing down but still showing some tread. Impressive.
~ B A D A S S ~
I am cost conscious and flat intolerant. I've been looking at the Panaracer Ribmo 26x1.5". It comes in foldable and steel bead. I think they both have kevlar protection.
I have schwalbe marathon supreme i think. well its the no2 best marathon tire. Really good grip and puncture protection.
Its not a plus tire with gel inside but its still very good. [ Technology Black Synthetic rubber Illustration 3d modeling
Marathon Supreme HS 382 | Schwalbe North America
I also run continetal contact 2 Continental Bicycle -CONTACT II
also veeery good grip and no punctures.
I could'nt find top contact2's Continental Bicycle -Top CONTACT II
otherwise i would have gotten those. they are probably better than the contact 2s.
I'm running these on dt rims and ihave experienced no problems whatsoever getting them off or on.
before i ran speed disc rims and Continental Bicycle -Touring Plus
They were called contact before and they have the plus gel inside. really fast tires but slightly heavy. totally indestructable and really good grip. used them for 4 years and they will run for about 2-3 more i guess.
get ones that are smooth in the middle!!
Continental Bicycle -Overview City / Trekking / ATB
City / Touring | Schwalbe North America
for winter time i use these nokian w240 SUOMI TYRES
much better than schwalbe ice spikers! (which i also used to a couple of years)
I haven't found anything that can ward off the dreaded truck tyre belt wire from puncturing my tyres. I've flatted with Marathon Plus and Durano Plus tyres, as well as IRC Formula Pro X-guard tubeless, Hutchinson Fusion 3 tubeless and Maxxis Refuse with Mr Tuffy tyre liners.
My next attempt will be setting up the Durano Plus tyres tubeless.
I am pretty lucky my commute is on a relatively rural bike path (rails to trails) between two small towns. Lots less of that kind of highway/freeway garbage hazard than some of you deal with. Maybe a thorn here or there, or a construction staple (took one of those through the tread of my rear Maxxis Ignitor and out the sidewall once) or nail now and again, but generally a lot less stuff.
I've got the Durano tyre on the rear sealed up on Mavic XM719 rims using Gorilla tape, Stans sealant and tubeless valves. So far they are holding air nicely except for one of the two puncture the tyre had. It's slowly sealing up though. The sealant hasn't come through the tyre at any other point.
~ B A D A S S ~
I question the necessity of tubeless commuter tires. When I was running the Contact 1 with gel inside I had zero punctures in 4 years. glass, sharp gravel, dope needles, heavy industrial sites and bombing into curbs doesn't break these. I've had similar experience with the contact2 and marathon supreme. Also I change tires for the winter and then its a hassle with tubeless and gunk.
I'm just looking for the best solution to my commuting puncture issue.
When I moved further from work (from 15km to 55km) I rode my first two commutes on my road bike with Conti GP4000S tyres because that's what I used on the short commute. Those two days destroyed the tyres. My fault, woring tyres for the job.
Then I went to Maxxis Re-fuse tyres, which I found punctured less at 130psi than the recommended maximum of 120psi. However I was still getting at least one puncture over 3 days of commuting a week. I chucked some Mr Tuffy tyre liners in and had it down to about one puncture a fortnight. But the road feel was horrible.
I bought a 6700 Ultegra wheelset for the roadie and some Hutchinson Fusion 3 tyres. This felt much nicer and while the truck tyre belt wire punctures sealed up without any problems, the F3s got cut up a bit and some of these didn't seal well.
I bought a cross bike specifically for commuting and set it up with 35C Schwalbe Marathon Plus tyres. These felt nice on anything slightly downhill and flat. Uphill sucked and the truck tyre belt wire still punctured them.
I was given a nice Scott Scale with a Rohloff hub that I set up for commuting as well and put Durano Plus tyres on it. They are the nicest feeling set up by far. Now that I've set them up tubeless I'll hopefully have found what I'm after. If not I'll just have to deal with it and fix the punctures as they happen.
But it doesn't hurt to try different options. :)
the bontrager aw1 hard case tires I got stock on my trek have been surprising good. 2 serious years of commuting and 1 not so serious year and I have yet to get a flat with them. Probably jinxed myself saying that.
Now I'm not bike expert so I can't speak of the quickness or feel of the tire, but for flat protection they're great.
Discussion Starter · #16 · (Edited)
Thanks for all the good suggestions, especially Schwalbe. I've completely overlooked them in the past. I ended up buying the 26x1.5 Marathon Deluxe HS 420 | Schwalbe North America . It was quite a wrestling match to get the tires on the rim because they are very sturdy tires. One feature that attracted me is the reflective sidewall. I commute in the early morning and want to make it easy for drivers to avoid killing me.
Black Grey Synthetic rubber
Bedwards Of The West
Late to the party, sorry. I've had good luck with Schwalbe also. Loved the reflective sidewalls on my Big Apples.
I'm approaching the 5k mark on my Serfas Drifters... they have been an awesome tire. I set them up tubeless from day 1 and I have had 1 flat (in two years), and that was from not re-charging the tubeless sealant and pushing my luck. I rotated them at about the 3k mark. they have tons of life left in them. The 'negative tread' design gives them tons of rubber to wear through before they're anywhere close to worn out.
Also, they make fun suction cup sounds when you lean into corners in the rain.
^Yes. I use the Kenda Happy Medium 700x40c. Great tire. I get about a year out of a rear tire, and 1.5 years for the front. These tires see dirt, road, and singletrack.
Remember: no amount of flat protection will prevent flats if there is not adequate inflation.
My commuter has 26" wheels so I started with Specialized Nimbus tires and put a Michelin City on the back when the Nimbus got a sidewall bubble. The Specialized Flak Jacket is pretty tough since I one went a full day with glass in my tire before it went flat. The Michelin City is even more bulletproof.
I also use my cross bike in nice weather and I have been running Forte 700x25c road tires with kevlar belts but I am thinking of getting some 700x32 Panaracers. I must be pretty lucky with flats because I have also commuted on the cross bike with Hutchinson Bulldog knobbies and have avoided flats so far.
1 - 20 of 32 Posts
