rad, good work man.
Look forward to seeing it in action up in the park.the.vault said:I fit a Specialized Command Post to my Trek Remedy, which took a little bit of work itself. The Trek takes a 31.6mm diameter seat post.
The shift lever ratio, is pretty close to the command post remote. The two pivot distances are very comparable. The way I have it set-up now, it is equal in throw to moving across 1.5 chainrings, if that makes sense.AL29er said:How is the throw on the shifter lever?
I have mine rigged up with a Joplin remote and do notice that I have to pull more cable to actuate the CP than I did on the Joplin, so I have more throw at the lever. Not a big deal and I do prefer the joplin to stock CP lever and proprietary cable.
The command post only comes in 30.9mm, which fits Specialized bikes just fine. No one was making a shim/adaptor to go from 30.9 to 31.6mm, which is the size of seatpost on my Trek.ae111black said:what did you have to modify to work the frame or the post?
