I assume it needs a rebuild but I have been using the post for several seasons (external cable version) I do get it serviced every year. I am experiencing intermittent slipping at full extension. It slips I get off it and it pops right back up seems to lock in and doesn’t slip for a while but will do so eventually. Before hauling it in for an overhaul I thought I would see if anyone here has suggestions for me to identify a user error that may resolve the issue.
A few things I have done so far:
- Checked the cable- it is not getting pulled anywhere that may be “activating” the post
- Checked the lock ring and found it slightly loose. Hand tightened it and re-pressurized the post was a little low but nothing too bad.
- saw the cable end pointing straight up and wondered if somehow my fat arse might be pushing down on it the just the right way to activate the switch and post (highly unlikely but I am in problem solving mode)
- When re-pressurizing the post I shook it- no parts rattling around inside
- Post goes up and down without issue
I assume something got in there and is preventing a lock key from engaging consistently but before I do bring it in for a rebuild I figured I would see if anyone here thinks I am overlooking something silly.
Thanks so much!
Thanks so much!
