Well It's winter in Minnesota now, and I was wondering if there are any possible ill effects from storing a bike outside in the winter when it gets real cold.
Thansk for the help
Paul
Thansk for the help
Paul
PMC said:If you're going to be riding through the winter it's best to keep it in the garage or somewhere unheated. No need to subject all the moving parts to the temperature changes from indoors to outdoors every ride.
Wow, that pic is so, ahem, cool!nwmtb said:PMC is correct, it's when the bike is subjected to in and out temperature changes that could damage a frame or parts. The garage will be perfect.
later, Chad
KERKOVEJ said:I work at a shop that has a college in town down in Iowa. Every once in a while we will get a college student that comes into the shop in early Spring with a chain stay that is cracked open like someone stuck a fire craker in it. What happened you ask? Well, they store the bike outside. The snow melts, the water drips into the frame. It freezes again. As it freezes, the ice expands and applies pressure on the inside of the tubing. BAMB! The frame is toast. Seen it happen atleat a handful of times.
Just something to think about.
huntforlife said:Thanks.
Yeah I'm keeping it in a secure garage, so corrostion isn't really an issue.
No pun intended....Rufudufus said:Wow, that pic is so, ahem, cool!
That road bike is looking pretty seductive with that feather boa wrapped around her neck. Hubba hubba. Must resist.nwmtb said:PMC is correct, it's when the bike is subjected to in and out temperature changes that could damage a frame or parts. The garage will be perfect.
Except for that one day in chemistry when the teacher explained how water expands when it freezes.Caffeine Powered said:now I've heard it all.
What you you think makes pipes burst when they freeze? What makes and engine block crack upen when the water within freezes? Why do potholes get worse in the winter? Water expands when it freezes with such foce that it will break whatever container it is in. It is entirely possible that a tube on a frame could get water trapped in it and burst when it freezes. He definetly isn't full of **** but you have shown us how to be an ass!Caffeine Powered said:you're so full of sh!t. we get the same weather here and that doesn't happen. if you're really worried about your bike give it two things... oil and grease. if I have to explain what to do with oil and grease you might just believe bikes in Iowa "blow up".
frames blowing up in winter... now I've heard it all.
Do whatever you like to your bike. You won't be able to prove me wrong. Your argument about assembly may or may not hold water/ice. Water being trapped in the tubes could also be a function of frame design and manufacture. 9% expansion can be more than enough to split a tube wide open or it may simply bulge the tube or it may not even be noticable. It depends on many factors like frame material, temperature, tube size,......etc. I suspect that Aluminum would be more likely to sustain major damage than steel. My other hobby involves steam engines. I have seen Sch 80 steel pipe burst from being frozen because someone forgot to drain the pipes. This pipe is much stronger than the materials used to make bicycle frames.Caffeine Powered said:water only expands 9% when frozen
and consider this if you have a bike assembled bad enough to let water into the frame at the top... it's gonna leak out the bottom too.
just to prove you wrong I'll fill my serotta with water and let it sit for a week. that's how sure I am that the Iowa claim is ********.
sexy...KRob said:That road bike is looking pretty seductive with that feather boa wrapped around her neck. Hubba hubba. Must resist.
Looks like that bike hasn't moved since you built it up. Even the boa is still clean.*rt* said:sexy...
hey! it's not easy to ride so fast you never get dirty.wooglin said:Looks like that bike hasn't moved since you built it up. Even the boa is still clean.
