1 - 4 of 4 Posts
Do it all or nothing
Just about to install my new crank and forgot to measure the chainline before removing the old stuff. Does anybody know the chainline for the 07 coilers, coilairs? Thanks.
Discussion Starter · #3 ·
... what is the actual measurement from the frame to the first ring... trying to set up my new atlas fr crank... got the bb worked out... just need the spacers in between the arms and the bb... funny little rubber things. The manual is asking for a measurement of 48,49 or 50 mm. How is it going lou_b_83? Long time no see.
An easier and more accurate way is to line up the middle ring (big if you use a bash guard) with the middle cog in the rear.
Install your rear wheel. Run your chain from the middle cog to the middle ring. Add or remove 'funny little rubber things' until the chain is straight.
1 - 4 of 4 Posts
