Im running a CC DB Coil CS, 500lb spring. HSC is set to 1.5 turns from fully open, LSC is about 18 turns from fully open. I can bottom the shock out by bunny hopping in the car park. Does this suggest an incorrect spring rate?
am assuming its an obvious answer of yes.....
I do have a 550lb spring. I think this would be better? I can't see how I can stiffen the existing spring up any more and it doesn't make much sense that I should be cranking on all compression settings to prevent bottom out on a bunny hop?
