1 - 6 of 6 Posts
Im wondering if it would be ok to put a coil shock onto my sanction, alot of people say coils perform better and i feel the sanction rear can be a little lacking.
I can get a fox van r with an i2i of 190 which is right but the stroke is 2.37" which is a bit bigger than the sanctions 2" stroke.
How much extra travel would i get and would it effect my bike in any other way if i did this?
Cheers, Jamie
Cheers, Jamie
By going to a slightly longer shock you will see your geometry change a little bit and get a slightly longer wheelbase (I think!). I am not a expert yet in the geometry dept!
I do feel that adding a coil to the rear of the Sanction has really woken up my Sanction. I added a CCDB to mine and love it! The ride quality is much nicer, the suspension much more plush, also the ability for the bike to act great over small fast bumps and bigger air is great.
I love it.
I love it.
CCDB, nice! How was pedaling performance after putting on the coil.
You cannot add a longer stroke shock to the sanction, I have tried it first hand and it will do funny things and hit the frame. Problems it will cause are not worth the extra 1.125'' of travel. Quality travel is worth more than travel # anyways. Your best bet is a Double Barrel 7.5x2.0. They work great with the sanction's high leverage ratio and can be tuned so that the rear end sticks like glue over rough terrain, has great "pop" off jumps & obstacles, and pedals very efficiently. If you can't afford the double barrel then a fox dhx 5.0 will work well. Call me with any questions if you want-920-733-0600 Ryan. Happy Sanctionings!
1 - 6 of 6 Posts
