Any clydesdales ride fat bikes? Good, bad or just cant ride the same conditions lighter brethren? And options to test ride Colorado northern front range to summit county. Thanks!
My guess is you would do minimal damage to set tracks but I would stay off them if you are not using XC skis. If there are skate-ski trails or snowshoe trails they might be nice for riding on.hackmonkey said:Colorado. Some on the front range when snowing and cold, enough snow on dirt, ice, and rotting drifts to make a normal bike riding bad to pushing. Some at elevation near the ski areas, packed deep snow from xc skis, snowshoes and sleds. Could I ride groomed nordic trails after hours and not cut them up?
I'm north of 260 lb with gear. trail damage is a function of tire pressure and snow conditions, more so than rider weight. You will only be able to ride traditional xc ski tracks without pissing someone off when the center ridge is gone, and the snow is on the icy side of ideal for skiing. lots of conditions where you wont punch up the track, but the tire is wider than the track, so it will cut into the side and the center ridge, which, even if it doesn't damage the trail at all, will piss off a lot of people.hackmonkey said:Colorado. Some on the front range when snowing and cold, enough snow on dirt, ice, and rotting drifts to make a normal bike riding bad to pushing. Some at elevation near the ski areas, packed deep snow from xc skis, snowshoes and sleds. Could I ride groomed nordic trails after hours and not cut them up?
Hey Hackmonkey, where you located? I'm in Loveland and you're welcome to come by and ride one. We have a large Pugs and will have a large Fatback in a week or two. I've been riding the Pugs in this area for 3 years, would be more than happy to give you some feedback. 1 ride and you'll be hooked!hackmonkey said:Any clydesdales ride fat bikes? Good, bad or just cant ride the same conditions lighter brethren? And options to test ride Colorado northern front range to summit county. Thanks!
depending on what frame you are on, 80mm rims will let you run more gears, and more easily run low gears compared to 100 mm rims too.Valhalla said:I put the 'dale' in clydesdale and ride 80s on a 2008 Ti Fatback up in AK. I imagine the 100s would work best for us in powdery conditions, but the 80s do just fine with technique. The 80s are a great balance for all conditions including snowless days.
