1 - 3 of 3 Posts
Seems like a dumb question but this is my first time using the cinch system and first time with an oval ring. I can't find anything on the manufacturers website that confirms how I should clock the white mark and 'crank arm' text on the ring to the arm itself.
Wood Bicycle part Hardwood Bicycle drivetrain part Gear
Bicycle part Bicycle drivetrain part Gear Crankset Circle
Looks to me like it should be rotate it 90 degrees from first pic, with the white mark in line with the crank arm, either under the crank arm or opposite the crank arm for nominal phasing.
1 - 3 of 3 Posts
