I've recently switched to clipless after a couple of years on flats and am struggling with the shoes sliding around while clipped in. I'm on XTR trails and Specialized Tahoe shoes. I've got them setup loose while I learn, but even at about 3/4 to full tightness on the pedal, I am sliding around a lot in turns, greatly reducing my confidence on more technical trials. I feel like I'm going to just slide out of the clip if I put any amount of lateral pressure on the pedal. I ride in Colorado so usually pretty dry and dusty.
Has anyone else had this issue? I was considering adding skateboard tape to the platform on the pedal around the clip before buying new shoes. I'm used to using my weight on outer and inner edges of the pedal for control when using flats, but just can't bring myself to trusting the clip with it moving around so much. I've considered moving to CB mallets, but have heard so many bad things I'd rather stay with old reliable. Any ideas? Are the shoes just terrible? I've looked at other shoes like the Terraduro and see the same vertical line around the cleat, leading me to believe I'd have this issue regardless of what shoe I wore.
These are my current shoes.
