1 - 20 of 27 Posts
· Registered
flats, too tight for clipless, due to having to take feet of the pedals a few times on each run (some trails are 2" deep dust and marble sized stones on top of off camber)
however, other places i some times ride i would consider clipless, but cant afford to just trial it out.
· Registered
The reason I use clipless is your feet are always in the right spot. I hate going through a ruff rock section and thinking about my feet bouncing around on my pedals, then trying to set them up quickly for the next jump or drop thats coming up.
· Ricky DH
I ride clipless for trail and DH, and will never go to flats.
The only negative I can find for clipless is sometimes having a bit of a problem gettng back into the clips in a rocky section. But to me, that one negative aspect does not override all of the positives of clipless.
· Registered
I hate that feeling. Being clipped out right before the hardest part of the track makes me feel helpless. That's why I wear flats with 5.10's
· Ancient Chinese Secret
Clipless can ruin your jumping technique. It did for me. It causes one to unnaturally rely on being attached to the bike (called "levelling your pedals" according to an instructor I had) rather than physics and technique for making the bike stay attached to your feet. In my case, It was causing me to nose in on my landings with a huge potential for major injury (e.g. OTB) which I almost did a few times.
After discovering that I had bad technique, I went to flats and haven't looked back. While I rarely become detached from the bike, that downside is not offset by the bad habits that clipless caused for me. It's also a lot easier to dab on tricky sections. Bailing on jumps gone bad is also a positive, but that rarely happens (at least for me) but has helped me out on occasion.
Imho, clipless is only good for XC or racers, but your mileage might vary. For AM, recreational DH or FR, flats are the way to go.
· Ricky DH
I'm definitely in the minority here, but it's just the way I learned. I used to ride/race bmx as a kid and of course rode with flats. Then I started riding mountain bikes with the cages, then progressed to clipless pedals. Now if i get on a MTB with flats, it feels totally unnatural. As comfortable as I am with clipless, I see no reason to go to flats. I ride, pedal, berm and jump just fine, no problems for me. As they say . . . To each their own.
· Registered
if u look at the top 10 and any world cup dh race, more often than not most of them are clipless. i think if you have the correct technique they are definitely faster than flats. i personally ride flats, and find clipless pedals scary and hard to use. to each their own as said before
· Registered
But Hill and Blinky can still tear it up on the steep tech tracks. Blinkensop had to hike a bike at Leogang and still finished top 5.
I think the number one reason that the WC guys run clips is so they can get the power down more efficiently. It, in my opinion, has extremely little to their feet bouncing off the pedals or being in the wrong position. Clipping in delivers more of the power to the ground. And in a WC race where hundredths of a second count, most of these guys can't afford to not be able to go flat out pedaling when ever possible.
· Professional Troll
Wow, so much noobery in this thread. (FYI I ride flats on my DH bike, clips on my trail bike)
1. Clips are faster, (almost) always, period. You can pedal a little better, but the main reason is they give you SOOOOOO much more control through the rocks and technical sections. You have way more control over your bike clipped in
2. Clips make many sections easier, but on the flip side can reduce your bike handling skillz development (the main reason I don't ride clips on my DH bike)
3. Clips rarely make any section harder or more dangerous for a skilled rider, even the most dangerous and technical trails are better on clips, period (only noobs disagree). I've seen only 1-2 trails that clips are more of a pain than they are worth on, but they are pretty crazy trails.
4. Did I miss anything?
5. Oh ya, everyone should learn on flats. As I said above, clips can make you lazy, and I've seen some TERRIBLE jumping technique from people who learned on clips, but never from people who learned on flats.
· calma
I ride with both depending on weather, course and how I feel that day.
I can typically switch without any real notice with regards to pedalling on a dh ride. Yes I do notice some difference on flatter (xc) type riding, but still make it work.
Regarding unclipping and foot placement no real issues; as I have had my feet come off with both and trying to reclip and finding right foot placement (flat) about the same.
With flats - shoe choice is the key; for me 5.10's work great (riding Shimano DX Flats with long / short pin combo). Feel pretty much clipped in as the grip is great, some times to grippy.
Best advise, ride the same trail, sections, etc with both and choose from that.
· Registered
Over the years the popularity and overall sucess on the WC DH circuit has gone back and forth between flats and clips. As of late it seems that clips are making a comeback on the WC for top finishers, but there are still a few top riders on flats. Ultimately I think you should ride both and decide from there. For myself I seem to change every year. One year on flats, the next on clips. I don't make the change on purpose, it just seems to happen. Things like wearing out my clipless shoes and not finding a new pair I like. Or when 5.10s were reintroduced a few years ago. Sometimes it's been and injury, or I've been DJing or MXing more than usual.
As for clips causing bad habits when jumping, I dissagree. Moving your bike around with your feet is an advantage of clips and should be used. However, when you go from clips to flats you have to relearn how to keep your feet on the pedals when jumping. For me it doesn't seem to be a problem. But I can also ride MX one day with front brake on the right and DH the next with front brake on the left. All I have to do is squeeze them once and I seem to reset to that vehicle.
The last couple of years I've been mostly riding clips as I've been doing more XC riding in the mornings. However as I write this post I'm nursing a broken rib due to not being able to get my foot out of my clips a 1/2 second earlier. Hmm..... maybe it's time to change again.
1 - 20 of 27 Posts
