1 - 12 of 12 Posts
· Registered
So ive been riding again for about 7 months. I am relearning technique.
Climbing steep hills, i lose rear traction when i move my ass and body forward and stomp on the pedals. This is how i used to do it.
I get 100x better traction when i place my chest down and move my butt back. doin this, i lay down the power by pushing the pedals in the vertical plane instead of horizontal. Like im folded in two and im kicking forward.
It works, but what gives?
· Registered
I'm a seated climber too. On most climbs, I just lower my chest to the bars. On very steep climbs, I also move my butt forward. Many times,I'm right on the tip of the saddle and very small weight shifts are all that's needed to maintain front/rear balance. Many times there's a very fine line between losing traction and the front end wandering or popping.
Air pressure in your tires is also a big factor in spinning out on very steep climbs. More so than the amount of tread.
· Registered
Discussion Starter · #8 ·
That is good insight right there.
Ive recently lowered my tires pressure in the back by 5 pounds, and it made a tremendous difference in climbing.
· Registered
Tire pressure is the most important performance adjustment you can make on a bike and judging by the people I ride with, and people I meet on trails, it's one of the most neglected adjustments.
Fine tuning the front tire pressure is even more important than the rear. Because when the front lets loose,not much you can do about it. How well the shoulder knobs grip is very important on the front, it's often the difference between going down or staying upright.
· West Chester, PA
This has been helpful to a few people I've given some advice to, but it is not based on any scientific research. I may have read it in a magazine or something years ago.
The #1 problem people make when they stand to climb is they put all their weight on the bars to alleviate the strain they're feeling in their legs. You need to be in a more aggressive crouching position and use your upper body muscles too.
On steep stuff, stay seated as long as you can. When you do stand up, try flexing your forearms downward with a firm grip on the bars, as if you're twisting motorcycles throttles with both your hands. This helps keep your butt rearward so you don't stop transferring power to your rear tread. You can try it sitting in an office chair. Put your elbows on the desk, make two fists, flex your forearms so you're turning your wrists down. Then try it while flexing your shoulders back. The try it all in one motion while pushing your butt into the chair.
· DynoDon
you need a 360 degree pedal stroke, smooth even power, no mashing, if you have a trainer or spin bike, you can put one foot on a milk crate and with the other try to learn to do a complete 360 degree power on, pratice that on both feet.
I've found I have a mental block on some hills, I get to a root section or a steep rise that has given me trouble before, and I defeat myself, I've gotten to the point I go back, and do it over, and over until I get it, then the next time it gets easier and easier, sure alot of it is technical, but I think its more mental, for me anyway.. good luck..
1 - 12 of 12 Posts
