Is it HT or FS?teleski69 said:Whenever I put force on the drivetrain or stand up and peddle, I hear a loud clicking noise near the bottom bracket. Anyone have an idea what this might be and how to fix it?
I had a very similar problem. Took off the cranks, pulled out the Bottom Bracked. One of the lockrings was plastic, and seemed a little loose in the thread. Took some plain white plumbing tape, put a couple of layers on the plastic ring. Put the bracket back in, tightened everything, the problem went away. You will probably need 2 tools. Crank Remover and BB puller, which shouldn't run you more than $25 at your local bike shop.teleski69 said:Whenever I put force on the drivetrain or stand up and peddle, I hear a loud clicking noise near the bottom bracket. Anyone have an idea what this might be and how to fix it?
The BB is the most likely culprit. Quick way to check without pulling everything apart - flip the bike over and press down hard on the crankarms with your arms (you may need to lean your weight on it). You may hear the click - you may even be able to see the BB cups move in the shell. Rotate the crank, do it again, keep doing it until you are satisfied that the BB is/isn't making the noise.kirrill said:I had a very similar problem. Took off the cranks, pulled out the Bottom Bracked. One of the lockrings was plastic, and seemed a little loose in the thread. Took some plain white plumbing tape, put a couple of layers on the plastic ring. Put the bracket back in, tightened everything, the problem went away. You will probably need 2 tools. Crank Remover and BB puller, which shouldn't run you more than $25 at your local bike shop.
Hope that helps.
[edit] just for the "DUH!" factor, make sure your pedals and cranks are indeed tightened in their sockets before taking the whole shebang apart. Sorry. I do tech support for a living.![]()
Yeah, I've got that problem with an ISIS crankarm right now (a Hussefelt). I reattached itwithout enough grease and it's been creaking like a mofo. Never had that problem with square taper - they seem to round out before they creak.liatdraH said:In my experience, when I have heard the dreaded noises in the BB area, it's turned out to be my crank arm. I have had the problem with both square taper and ISIS.
