I have some cheapo spd cleats that I am trying to get off my shoes. THe problem is one of the screws is stuck. It is a very shallow allen head, and it was hard to get grip with L handle allen wrenches.
Plan 1:
I soaked it with some liquid wrench and tapped it with a smal hammer, let it sit, and repeated. I put some heat to it. Repeated the liquid wrench treatment. I finally got a higher quality allen wrench and put some torque on it, and it started to strip out the head.
Plan 2:
I got a screw extractor. Drilled out the screw with the appropriate size bit. Then I put in the extractor, and the screw would not turn. A little more persuasion resulted in a braken extractor. Now I am thinking I am in some serious trouble.
Plan 3:
I was thinking of grinding a slot in the top of the screw the right size for a massive flat head screwdriver (I would have to borrow the dremel). Then I could get some traction and perhaps break the screw free?
Honestly I am lost for ideas. I have used extractors dozens of times before (mostly on screws with broken heads, not on stuck screws) and never had one break. Any suggestions?
Thanks in advance.
GF
Plan 1:
Plan 2:
Plan 3:
Thanks in advance.
GF
