Use it as it comes from the box. The inside of the chain will never be as clean or well-lubed as it it when it's new. If you ride in dry conditions and are concerned the coating on the outside will attract dust and grit, try running the chain through a rag lightly dampened with mineral spirits or some other solvent to clean the lube off the outside of the chain only.
