1 - 3 of 3 Posts
I was going to switch my pads on my Martas and I usually take a cotton swab and wipe out as much as I can around the piston. Is there something I should use to keep the pistons moving freely? Maybe a thin layer of some kind of lube around the seal of the piston?
No, that's not phonetic
The only "lube" that is recommended is Magura mineral oil ("Royal Blood"). Try this: advance the pistons out a bit (squeeze the lever slowly), dribble a few drops of mineral oil around the pistons, push the pistons back in, advance them again, add a bit of min oil, etc. Do this a couple of times. Push the pistons in one last time, floss the inside of the caliper well with a nappy rag, and install the pads. Any extra oil remaining could foul the pads, so err on the side of wiping the inside of the rotor slot out well.
Discussion Starter · #3 ·
thanks, I will try that when I put the pads in
1 - 3 of 3 Posts
