Clean & lube freehubs or replace?
1643 Views 7 Replies 3 Participants Last post by  Cleared2land
I have been going through the Giant Sedona I bought this past Summer and that included disassembling, clean & lube of the freehub. When I pulled the hub out, I saw that it had no lube inside, but it didn't seem to be worn. I don't know if this means that some kind of persistent lube was used, or maybe it wasn't ridden much, but I was taught that when bearings are used in applications where they're stressed badly, they should be greased. Obviously, this isn't as extreme as a car's wheel bearing and it doesn't turn at high RPM, but avoiding wear is the goal, right? I mean, the bearings in the hubs are greased, so why not the freehub?
I used marine waterproof grease and it's a bit sticky, but on the trainer, it doesn't seem to cause me to pedal harder, but I have been told lately, by people who service bikes, that they use oil. One said I should use TriFlow and yesterday, the guy said they don't even work on them- it took ten minutes to completely tear it down, clean & lube- why would they not do this?
What is the typical lube for these? I have Phil's Tenacious Oil, BoeShield, TriFlow and others- or, should I do what the service manager told me when I asked which grease I should use? He said "Use one of the slippery ones".
1 - 8 of 8 Posts
Hi, not to confuse wheel bearings and free hubs, bearings actually bear axle weight and use a heavier grease and free hubs primarily drive hub engagement and need a lighter grease or oil. Both should be regularly serviced.
I really like DT Swiss Star Ratchet Grease and use it in all my freehubs.
Hope this helps!
How about a photo and a brief description of your freehub?
Same as the one in this video-
I think I'll just disassemble it and use lighter grease or my Phil's Tenacious Oil- it only takes a few minutes.
Hope this helps!
Right- 1/8" freehub bearings, not the bearings for the axle.
Okay, you have a freewheel, not a freehub?
You have loose bearings and I would suggest a lighter bearing grease. Perhaps not as thick as a marine grease.
Yeah, freewheel (looking for a suitable symbol to show embarrasment). I haven't done this much service on a bike in a long time and had forgotten a lot of the names for various parts.
I have White Lithium grease- I can use that. I bought a new tube of it for the bike. I have some Quicksilver 2-4-C grease, too- it's a Mercury Marine/Mercruiser product, for use on their products, but it's not as heavy as the typical marine grease. I used it on the headset bearings (sparingly) and a few other places.
1 - 8 of 8 Posts
