1 - 9 of 9 Posts
· MTB Rider
I would like to go to full cables on my Giant Yukon. But I also want to move the cable from underneath the top tub to OVER the top tube so the bike doesn't rest on the cables when it's sitting on a bike carrier.
Are there any parts out there that clamp onto a top tube to provide 3 standard cable guides???? I have no problem with Zip ties on the fork, but for this application, I'd like to keep the cables in their proper place.
· Registered
I've used the stick on guides for over a year with good results. They are very secure. I went to full housing on my rear brake because my old frame had the stops on the right side but I wanted to run V brakes.
stick-on cable guides:
http://www.jensonusa.com/store/product.aspx?i=CA707Z01
I've yet to see a clamp on cable guide with three slots. The closest thing that I've seen is a clamp on cable stop with two slots. You could make it into a guide by drilling it out so that the full housing can pass through, but it's still only 2 slots. I used this to convert my bottom pull der. to a top pull.
Clamp-on cable stop (They have sifferent sizes):
http://www.biketoolsetc.com/index.c...ng&tc=Clamp-on Cable Stop&item_id=TK-105A/38B
· Registered
stupidgringo said:
could you describe or post a picture of your rear brake cable setup. I'm in the process of installing v-brakes on an older steel frame, and I'm kind of struggling with it.
Thanks.
Ron
Here's my FS bike that I ran full housing for the rear brake. The main reason that I did this was because I didn't like the down tube routing of the front der. cable. I used the frames cable stops on the left side for my front der. cable and then added the Problem solvers stick on guides for my rear brake cable. If you look closely, you can also see the clamp-on cable stop on my seat tube to enable the use of a top pull derailleur.
· Registered
stupidgringo said:
That's exactly what I did last night, and it seems like it will work well. Have you had any problems with the housing popping out of the guide while riding?
Thanks again for posting the pic.
Ron
No problem with the housing coming out. The zip tie, in the picture, wraps around the housing and holds it in.
· Registered
Good advice.
I think I will setup my KHS frame like this too.
Thanks for sharin'
· Registered
Stick on guides suck
I have tried them but they always came off within a month or two. Tried them on frame, fork, etc. Just a matter of time. They do work, just not for very long. Personally I would recommend not wasting your money on those little overpriced pieces of plastic.
Strictly opinion from here down:
I really like down tube cable routing. Clean, simple, less friction / bends than top tube routing... what didn't you like about it? Just curious.
· Registered
I've had good luck with the stick on guides, going on over a year. I don't expect them to last forever. I do agree that they are over priced, though. As far as top vs. down tube routing it's just my personal preferance. I have no doubt that bottom pull works great. I just don't want a cable looping under my bottom bracket shell.
1 - 9 of 9 Posts
