1 - 5 of 5 Posts
Has anyone had a problem with the cassette digging into the drive-hub? I have a set that is only 8 months old and started hearing a creaking noise under load, so I took the cassette off (hard to remove) and noticed that the drive hub had little dig marks on each spline. Thanks.
Old man on a bike
Aluminum freehub shells will do that, and not just on Kings, this is why they recommend cogs on a carrier or spider rather than loose cogs. There is an option for a steel shell that is more resistant, but heavier. Some find that it makes for harder removal of cogs/cassette but a little artful filing can take care of that...
Lets RIDE!
Torquing the cassette lockring down tighter may eliminate the creak. I find it hard to know when it's tight enough. And i don't suppose a little anti-seize grease between the cassette and freehub would hurt anything, would it? (probably collect dirt though...maybe not such a great idea?) Like Bikinfool said, aluminum freehubs will get marked, but no big deal. The price to pay for lighter weight I guess. My Hadley hub is the same way, but no creak so far.
Jim
The Bubble Wrap Hysteria
Marks on an aluminum drive shell are expected after prolong use. Consult the King website for the service manual. Over the last three years I have converted my King wheelsets to Stainless Drive Shells. I cross threaded an aluminum drive shell one time because I was in a hurry.....never again. Make sure you're a cassette that has a "spider" verse the cogs riveted together and make sure you torque the lock nut to 30 lb-ft according to my King lock ring.
Here is a really cheap trick, that works!
-i done it many times with my Kings, -you take some normal clear tape, and
wrap it around, working it good into the splines, i do it putting the tape on from that side of the of drivehub that is facing away from the spokes, so you have a bit of tape sticking out, after you put on all the cogs, now it will get a bit harder to get the
cassette back on, but that is precise what will keep it sitting tight.
1 - 5 of 5 Posts
