Chris King ISO LD 6-Bolt Disk 100mm x 15mm Front Hub, Velocity Dually i39mm x 26in Rim, DT Swiss Competition Spokes and Aluminum Nipples, Maxxis Minion DHF 2.8 and VEE Trax Fatty 3.0 Tires.
The wheel is built 3-cross with double-butted DT Swiss 2.0-1.8 Competition spokes and DT Swiss aluminum nipples. The wheel has been checked for true and only required a touch-up truing. The rim is a 39mm inner width 26 inch Velocity Dually rim, and has no dents or dings. It is taped and ready to run tubeless.
Two plus size tires are included. They are:
1) a 26 x 2.80 Maxxis Minion DHF, 120 TPI, 3C MaxxTerra (triple compound), EXO, folding bead, tubeless ready tire.
2) a 26 x 3.0 VEE Tire Co. Trax Fatty, Silica (multi compound), folding bead, tubeless ready tire.
Both tires have a lot of tread, and no punctures or cuts.
The hub bearings have been repacked with fresh Chris King grease.
$180 + $10-30 shipping (depending on location in the U.S.)
