The VT headsets are Semi-integrated A.K.A. Zero Stack A.K.A. internal headset. The European site correctly lists the headset as semi-integrated I'm using a Cane Creek Zero stack 2 headset. Went throught the same thing about a month ago when I bought a frame without a headset.zurC atnaS said:I thought Giant used Internal headsets on the VT, which is entirely different and better than integrated. Chris King produces an internal option, but you are required to make some mods.
tell them it's the one that's supposed to fit an aluminum NRS - 2001 is the one I had. It also fits my AC1 2003 model and my Mongoose Sommet 2001, and my Jamis XLT 2003.synkronized23 said:So where can I get the adapter to convert it to use a conventional headset? I want to transfer my Chris King over from my Fuel when I swap over all my parts.
Is it any particular brand? Or is it generic Giant?Reek said:tell them it's the one that's supposed to fit an aluminum NRS - 2001 is the one I had. It also fits my AC1 2003 model and my Mongoose Sommet 2001, and my Jamis XLT 2003.
REEK
I understand you wanting to use your hyperexpensive CK on your new ride but a secret of the biking trade is that a correcly installed and maintained headset of any brand and almost any quality will outlast the frame unless you're doing North Shore type stunts.synkronized23 said:Is it any particular brand? Or is it generic Giant?
Poon
Immediately after I purchased the bike, I swapped out the stock Titec stem for an extra Thomson stem that I had picked up cheap somewhere. While apart, I examined the headset, removing the cartridge bearings and taking a good look at them. I was very impressed, they seemed solid and were definately well sealed. Much better than any other non-CK heaset that I have looked at. I have a CK on a GT Zaskar singlespeed and while I am big fan of CK, I would be hard pressed to believe that I could tell a difference between the stock FSA and a CK in function and durability.Warp2003 said:I understand you wanting to use your hyperexpensive CK on your new ride but a secret of the biking trade is that a correcly installed and maintained headset of any brand and almost any quality will outlast the frame unless you're doing North Shore type stunts.
Get an internal (ZS) headset from Cane Creek or FSA... try to find out a post about people complaining about defective ZS headsets on Giants... most don't even know which type of headset it is... that trouble free these headsets are. You never need to look into them, they are less exposed to dirt and mud, they make a solid connection despite what CK's marketing says about them.
As I said before, CK's comments on the ZS headsets are their pathetic response to a product standard they can't match. The CK's "Perdido" (and it's lost on the market, BTW) is supposed to be the CK's ZS version but it requires reaming the headtube (not a good idea) to accomodate the "new and better standard" CK proposes. All in all... pathethic from CK. They're better off making good standard headsets and stop beatching on other companies/standards.
The ZS or internal or semi-integrated standard is here and it works. I dare to say that they are less sensitive to tightening pressure than standard headsets but it's maybe only my opinion. They are less exposed to mud and dirt as I mentioned before and this is a must for any MTB component.
