1 - 7 of 7 Posts
· Registered
Hello,
Just wonder if I can use the lower cup of this headset up (external cup) and the upper one down, cause I’ve fitted this to my 2011 DHR and seems that slackened even more the headangle. . .
Any suggestions will be appreciated. . .
· Banned
Hello,
Just wonder if I can use the lower cup of this headset up (external cup) and the upper one down, cause I've fitted this to my 2011 DHR and seems that slackened even more the headangle. . .
You have one of these right? Take a look at that recessed bearing contact in the upper cup. Do you think the lower race will not contact the cup's edge? :skep:
Edit: what you may be able to do is get a lower cup/bearing for the Inset 4 and replace your ext lower cup... Or, if you're using the 888, get a flat lower crown from Risse Racing. I believe this will get you 3/4 to a full inch of A2C knocked off.
· Registered
Discussion Starter · #3 ·
What I'll probably do is buy a new lower cup/bearing for the Inset 4 then, cause I'm using Boxxers.
The fact is that I didn't expected the headangle to change that much, cause DHR was designed (I think) with an external lower cup while using the Fox 40s.
Thanks anyway...
· Banned
Thanks anyway...
Have you thought about Cane Crik's Adjust-o-set?
1 - 7 of 7 Posts
