1 - 13 of 13 Posts
So I got two CK mountain bb`s for xmas but only need one. I cant easily return the one, but reading on the CK website it says
"There are, however, instances of compatibility where a "MTN" cup will be used for a "road" crank."
So I am trying to figure out if the mountain will work with my shimano r700 crankset on my cross bike. I emailed king and am waiting for a response but figured I would post up here also.
It depends on the BB width. Most Mtn bikes are 68 or 73 mm shells (DH bikes have wider). Road bikes also use a 70mm width. As long as your road bike doesn't use Italian threading (whole different issue) the cups should thread in, it is just the spacer width between the bearings. If your road bike has a 68mm width you should be golden.
Never trust a fart
The overall width of the BB cups is different from road specific cranks to MTB specific cranks. There is a small chance that the compatibility will be fine, but its not the norm.
I installed a CK mountain BB on a customers bike. The customer provided the BB for me to install. The crankset did not seat properly as to compared to the original BB that I removed. I had to have the customer get me the "Road" version of the BB for it to work properly on his road frame.
Discussion Starter · #9 ·
I heard back from CK today. The person I talked to said that I would probably need 1 or 2 1mm spacers. Says the mountain cups are 1mm narrower than the road cups. So to get it to match up I would need a spacer to add the extra space.
GAME ON!
does anyone know if the opposite would work? i.e road cups on mtb. without using the inner sleeve part the cups are essentially the same save for the 2mm total difference but that might actually help in regards to chain guide spacing and whatnot. curious to know as the colour i want is cheaper in road than mtb.
I'm wondering the same, a chris king road bb on a 1x mtb setup?
1 - 13 of 13 Posts
